front driver side headlight keeps going out
clandr1
Dallas/Fort Worth, Texas
is the connector burnt? does it have any black marks anywhere on it?
i had an issue where the bulb was fine, but wouldn't turn on. tracked it down to a bad connector so i cut it off and installed a new one i bought at the auto store.
V
VikingTrad3r
hi and thanks. im willing to snip and solder new connectors for sure as an attempt. really dont like mh wife burning down the highway in a blizzard with one headlight.
my connectors do not look burnt.
can you post a photo of or pm me and ill give you me wmail addy. id like to see the connector you rnr'd and ill have a good look at it.
thanks.
V
VikingTrad3r
thanks, is this the pigtail that comes up from the lower light?
V
VikingTrad3r
checked my connector as pictured above. no signs of heat whatsoever.
so i really think its got to be an excessive bibration/movement thing.
when I install the bulb correctly, I can wiggle it quite a bit in the socket. There's a little plate with torques bolts holding it on and that plate appears to be mildly worked a little bit allowing for the excess motion so I took some tape and wrapped it around the tabs on the ballast of the bulb and the fitment is much tighter with zero movement now so we'll see how this goes. Good thing these bulbs are only eight dollars
V
VikingTrad3r
so far the new bulb is still working after being secured from excessive (i think?) movement.
V
VikingTrad3r
well i have to knock on some wood but so far, adding a bit of black tape (1 layer) around the tabs that secure the bulb in after turning it, the effect of tightening up the connection, has worked.
light is still working after a couple weeks. the last 2 replacement bulbs have died within days.
5280Racer
Peyton, Colorado
As any Chevy tech will tell you in here... I have replaced more pig tails then you have changed your socks!!! very simple dealership sells them whopping 20 minutes if you're slow to cut solder and heat shrink new ones.
V
VikingTrad3r
thnx. does excessive movement count as a reason why they were replaced? i was under the impression from what inreadbtgey were typically changed because of burnt plugs.
RepublicanRebel
