I would like to know the truth about lowering the front end of these hoes..
I currently have Belltech Torsion keys and Belltech Drop II shocks on the front..
Ever since the beginning I've had horrible camber issues with no solutions
The adjuster bolts used to be only about a half turn in and it was about half an inch from tucking tire
Had -4º camber
Did a 1" body drop and I was tucking tire but ended up not being able to drive like that very long
Raised it up 3 turns on the torsion bolt
Got it aligned and they pulled 2º out but thats with the cam bolt maxed out
The front end kept settling so I kept turning the adjuster bolt until now its almost maxed out and I still have the same amount of drop
I would like to know an honest answer..
Between the 3 ways that I know to lower a tahoe static what are the pros and cons
Torsion Keys
Lower Control Arms and
Spindles
from what I've gathered..
Torsion keys are the cheapest and mess with the alignment the most
Lower Control Arms ride the best
Spindles you lose turning radius
Would lower control arms and stock torsion keys be my best bet for getting rid of my negative camber?
Where's Tony to sell me them the cheapest?
Had -4º camber
Torsion Keys
Spindles
