Front end noise
setconstr
I have the 3/5 Bell tech lowering kit on my 05 Tahoe with 22" wheels . A complete kit , spindles , sway bars, shocks, etc. when I turn the wheel at low speed I hear a kind of clunk in the front end what do you think this is ? Thanks
Multnomah Falls
Who installed the kit? Have you done any inspections at all? If so, what were they and how did you check for them and what did you find?
setconstr
setconstr
No I was scheduled to have a shop check it out but everything is closed now . Car drives Awesome and straight just noise at low speed as I'm turning
lowAZhoe
Resident GM Tech
Phoenix, AZ
Depends on the clunk. Could be a few things. First thing comes to mind is the intermediate steering shaft. Then there is also possibility something is loose on the front end from lowering or worn out. Control arm bushings, ball joints, inner or outer tie rod ends.
setconstr
setconstr
I have the new shaft to install along with a steering damper a carpet kit my whole dash an mtx subwoofer and amp some 07 front calipers .......Thats pretty easy one I may tackle it tomorrow
setconstr
setconstr
Replaced the intermediate shaft today but still hear the sort od creak when turning at Low speed . On to the next thing tomorrow I have the Pitman arm and Idler arm and gear all ac delco professional.
Byoung1330
Cookeville tn
Replaced the intermediate shaft today but still hear the sort od creak when turning at Loe speed . On to the next thing tomorrow I have the Pitman arm and Idler arm and gear all ac delco professional.
I would check the sway bar links also. I had a clunk in mine after I lowered it. I did mcgaughys spindles. New ball lower ball joints New upper control arms. new sway bar bushings. new end links inner an outter tie rods. Idler and pitman. The works an it dont make a peep.
Speedslow
I recently installed a 3/5 djm kit and after driving for a few hundred miles started to get a little clunk noise. Re torqued all suspension bolts and now it’s nice again. But it could be anything best bet is to put it in the air and check ball joints, tie rod ends, wheel bearings etc.
setconstr
setconstr
I just installed new front upper control arms, inner and outer tie rod links, pitman, idler arm and gear ( all ac Delco pro ) so everything is new also added steering stabilizer, its getting aligned right now didn't hear a peep out of it ....rear is next but I thought I would go Spohn but now I'm undecided maybe just Moog upper and lower arms .
conrual777
