Front end parts question
pnwdan
Cunning linguist
Arlington, WA
I had almost the same issue with mine. I replaced the entire front end which cut it down about 25%. I replaced my tires after that and it cut it down about another 70% but I still had an ever so slight vibration at 70mph. After going through everything I decided to change out my front rotors. As you see for me it was a combination but mostly tires but anything that rotates can effectively add vibration.
Dustinh
Dustinh
I appreciate you chiming in on this since you had the same thing. I've done my brakes rotors just recently. I think new tires, shocks and spacing out and replacing my jounce stops is going to be the trick
BeenChevy
Minnesota
Hey Dustinh,
In your case i'm confident the tires are the likely culprit and majority the issue. However, as you know, there are other components that will drastically help in conjunction.
Here are the jounce stops I went with from energy suspension:
http://www.energysuspensionparts.com/9.9117
-Think I ordered them on ebay for less than $20
I've converting most of my bushings to energy over the years on a few trucks and am VERY impressed with the durability. Here's some of the other parts that incorporate the energy bushings for our trucks:
http://www.energysuspensionparts.com/products/chevrolet_tahoe_4wd_2005
After cranking a Tahoe and Yukon I had to figure out how to improve the ride and probably invested more time and effort than it would have took to fab and install my own lift. I swapped around a total of 9 different sets of 33's and am currently at 25k on a set of Atturo Trail Blade's (33x12.5x20) on 1 truck and a fresh set on another and cannot say enough good things about them. They save you $ if you're thinking of going Nitto and very comparable in my opinion. -> I've run 2 sets of grapplers (trail and dune).. great tires also yet for the $ I choose Atturo. I'll be trying out their XT's next.
mattt
Yes Moog is good stuff and no issues with them. Part of cranking up keys creates a gap between LCA and jounce so get a 1/2" spacer between jounce and mounting point so there closer to LCAs. How much gap do you have now between them?
I haven't spent any time seeing how the jounce bumpers are attached, but is there enough extra fastener there to be able to add a spacer below them to move them up? What have people used to space up the jounce bumpers after cranking a bit? I'm mildly cranked(not leveled out), and the jounce bumpers are no longer touching. I'd like to correct that.
BeenChevy
Minnesota
Depends. The stock Z71 stops are longer so if you don't already have those, I think you can replace yours with those (correct me if i'm wrong). My trucks have tabs that hold them in and removing them prior to installing the lower stops was helpful. I was able to remove them by sticking a screw-driver in the center-hole of the stock stops and yanked side-ways to force them out of their tabs. Using a flathead was able assist the rubber back into the locking tabs to re-install.
I recall the steel only being 1/4-3/8's thick on the lower arm so there was enough thread to space underneath if necessary, however mine made subtle contact after letting the truck down off the jack. Just measure the gap prior to lifting the truck off the ground and see how much room you have between the arm and upper stop, you can get larger ones than I did if you need. There's lots of shapes to choose from. Depending on the upper stop you may want something more or less tapered or even round.
mattt
Mine has the taller, stock Z71 jounce bumpers, since it's a 2004 Z71 4wd Tahoe.
Dustinh
Dustinh
Hey Dustinh,
Thank you for your advice. I've been contemplating the atturo's over the federals just to try them out. And I'm pretty confident now as well that most of my problem is tires/balancing. Hopefully a rim is not bent. That gives me a solid starting point
mattt
How are you able to affix the 1/2" spacer between the jounce and the mounting point? On the 4wd Tahoe's I've seen the jounce bumper is just pinched in place in the permanently welded in place mount cup.
BeenChevy
Minnesota
Nah it's only pinched in their. Take a screwdriver, sick it into the center hole of your stock jounce and turn/bend it sideways until it detaches
mattt
You are correct...it is only pinched in there. The question is how did the original poster I referenced add a 1/2" spacer to a pinched in place jounce bumper???
Levi0320
