Front end rebuild
BigUnLuke
What did all this cost ya? If you don't mind telling. I'm about to do the same on mine.
Brock
Senior Member
NC
Just replaced upper & lower ball joints, control arms & CV axles. My guy did it for about $1000. The 325's are killing me! 159K
Brock
Senior Member
NC
IDK bill was not itemized. But that price included sy oil change plus oil pan gasket replacement.
A
arveetek
Granby, Missouri
I spent nearly $600 for quality Moog parts. I did all the labor myself, followed by a $45 alignment at a local tire shop.
Casey
BirchyBoy
I had the ball joints and sway bar links replaced yesterday. When I got home, I took a look and they sway bar links were installed opposite of yours (your pic below):
Is this going to be an issue on mine?
Jerky Arm Ape
North East Louisiana
BirchyBoy, the threaded end faces the upper A-arm?
Mine is installed like that to make it easier to put a socket in the lower a control arm.
The threads were interfering with the upper a-arm so I had to remove some.
Just to be clear, that isn't the correct way.
Ejwr
