02YukDenXL
- Joined
- Aug 11, 2014
- Posts
- 44
- Reaction score
- 4
Good morning folks,
So my front right hand axle seal has been leaking. It's been oozing from the 6 bolt flange (Photo #1, cv axle removed, flange only) between the axle and cv axle shaft. It's an '02 Yukon XL Denali AWD. The boots are worn on the cv axle so that's completely out as I'm replacing it anyway. I have the housing unbolted from the differential (5 bolts) and also the two 21mm nuts that hold the housing to the support bracket/frame (Photo #2). From all the videos I've seen, the housing and axle literally fall off the differential but mine is doing anything but that. Is my axle stuck in the differential? Am I missing something? I've done axle seals before on other vehicles but not on an AWD truck. My Haynes manual said something about using a punch and a hammer to free the axle from the differential side gear. My best friend used to work at Chevy and he's coming over to help me tomorrow if I can't figure it out tonight. Any help would be appreciated. Thanks.
