Front Wheel Bad Bearing and Hub?
stgolling
2008 GMC Yukon 5.3 flex 2WD 175,000 miles.
I have been feeling this vibration from the front of the vehicle for sometime now. It's not an alignment problem. I jacked up the driver side front wheel a few minutes ago. Putting my hands at 9 and 3 on the wheel there is a small amount of play when wiggling on the wheel.
Does that point to a bad wheel bearing and hub assembly or something else?
I had the EXACT SAME ISSUE. Turned out to be a bad u-joint in the driveshaft. Sounded like bearing at about 70 mph. U-joint replacement fixed the issue. good luck!
09YukonHybrid4x4
