FS - 07 plus GMT900 Kelderman Air Ride System - $3000
Status
Not open for further replies.
yates ™
Resident Apple hater
Iowa
I don't think my question was quite understood. Seemed like you were talking about taking my assembly out and replacing it with this one. I meant the struts itself(shock) can the sleeve bag be put onto any strut for instance a bilstein?
What is the diameter of your Bilstein shock compared to a factory one?
Blazed
Accepting Donations
I'm not sure but it doesn't have to be the bilstein I was just trying to get my point understood. If it's easy to apply the bag to a new strut in the event that one goes bad.
yates ™
Iowa
The system is designed for factory shocks and the end user would have to confirm whether they will work on aftermarket shocks. Sorry that isn't as clear of an answer as you are looking for but shock diameters can vary so I do not want to tell you it will work if say bilstein has different shock applications for the same model.
Yates, will this work on a Yukon hybrid?
Honestly I cannot remember if the hybrids have any differences but I will find out for you.
Blazed
Accepting Donations
That is more than clear enough thank you.
yates ™
Iowa
To my knowledge no one has done one but I am not aware of any reason why it wouldn't work.
soulsea
Bar
Iirc the base Yukon/Tahoe hybrid suspension is the same non autoride as the LT with slightly different shocks to account for the battery weight ... double check on this of course on your end.
The thing you have to make sure is that you are able to instal the system the same way as the non hybrid suvs, because a few things are laid out differently under the truck.
yates ™
Iowa
We have not had one in the shop to try a kit on.
Status
mohammadamlih
