Fuel cell in a 2006 suburban LTZ 6.0l ?? HELP
lewisport, Ky
Needing some help and advice, we're putting air ride on my sub and I don't want to take a chance on dragging the gas tank so since I already have the spare tire brackets cut out I plan on throwing a fuel cell under there but I was wondering what all ill need...
-Fuel cell with a gm sending unit
-any fuel cells that come wih pumps in them??
Or if not can someone point me in the right direction for each part ill need to do the swap
Thanks guys
groundscr8pr
flaccid member
scarborough maine
have a cell made from aluminum.. you can get mounting ring to allow the use of the stock pump/sender. check ekstensive or any other shop that does custom work. i had haggard fab build mine.
QUYHMK
