Fuel Economy question
TahoeTaz
TahoeTaz
Jersey
I've been using 87 octane gas (always from either Shell or BP... usually Shell), the stock 20" rims (I'll think about 22's once I wear out the OEM tires). As far as my highway MPH, I'm usually around 70-75, and I tend to cruise, and avoid a lot of braking and accelerating. After this weekend's road trip, I'm getting close to my first oil change, so I'll see where I'm at with that.
I'm used to low MPG, my Tahoe gets around 11-12 mpg with the larger tires, but I expected more from newer truck. And I am relying on the DIC, I'll start doing my own math, and see what I end up with.
mfdrookie516
Loading.......
Running late for work yesterday, I was cruising at 78 on the interstate. I reset my DIC just as I got to cruising speed, and watched it the whole way. I saw an easy 3 mpg difference from my normal 65 cruising speed.
jerrito1
Atlanta
I get an average of 17.5MPG in 2011 Tahoe. I drive mostly highway at 70-75 MPH. Haven't been able to get anything better than that for mpg
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
Keep in mind, with the higher compression NNBS engines, the 5.3l needs an minimum of 89 to run efficiently, even on stock tuning. One tank wont show huge results, but run a few tanks of 89 through it and see if your MPGs change.
Sent from a jelly bean.
GM Customer Service
Michigan
I just bought a '13 Avalanche LTZ, and my mileage, seems to be a lot lower than what the sticker says. The truck is stock (except for tints and black bowties), I keep it empty, and while I'm not the softest driver on the streets, I'm not racing off every stoplight, either. Right now, I'm averaging about 13 mpg city, and around 17 highway (vs. 15 and 21 sticker). Is this what I should be expecting, or is something wrong?
Hello TahoeTaz,
I hope you are having a great day!
Please remember that the MPG that is displayed on the sticker is an estimated number. EPA tests are designed to reflect typical driving conditions and driver behavior, but several factors can affect MPG significantly. The EPA ratings are a useful tool for comparing the fuel economies of different vehicles but may not accurately predict the average MPG you will get. Many factors may cause you to be averaging 13 miles or less miles per gallon. Examples of some factors are maintenance, tires: Improperly aligned or inflated tires can lower fuel economy by increasing rolling resistance. Likewise, performance tires and/or tires with larger "contact areas" can cause as much as 3 mpg lower fuel economy when compared to regular tires, Air filter: A dirty air filter makes the engine work harder and decreases fuel economy, Brakes: Brake drag can have a significant negative impact on fuel economy, Suspension: Vehicle suspension misalignment can cause poor fuel economy, and Fuel: A vehicle's fuel economy depends on the energy content of the fuel on which it runs. The use of oxygenated fuels or reformulated gasoline (RFG) can cause a small decrease (1-3%) in fuel economy.
I hope this helps,
Jennifer T.
GM Customer Care
Brock
Senior Member
NC
Taz, any GPS will give you an accurate speed.
Evildude!
TX, US
I'm thinking about getting a Tahoe and I gotta admit the MPG is a scary!
Great looking truck tho.
Kenric
Howell, MI
I am getting a pretty solid 16.5 MPG combined in my '13 YXL Denali with the 6.2L.
Only 1700 miles so far but soon I will switch to Mobile 1 oil and if it goes like it has in the past, I might see as much and 0.5 to 1 MPG more.
I also run about 45 PSI in my tires, and that helps.
What Jennifer T says is right. There are so many things that can impact fuel economy that people don't think of, or are not aware of.
A big part of my job is evaluating fuel economy.
One of the biggest things I have seen impact FE is switching to larger diameter wheels. A big thing that people are not aware of is that when you accelerate a vehicle, you not only need energy to change the speed of the vehicle, but you also need energy to spin up the wheels. The heavier the wheels are, and, the larger the diameter, the more energy is required. In fact, the Polar Moment of Inertia of the wheels is a function of the square of the radius. So, a small diameter increase of the mass can result in a large increase in the Polar Moment of Inertia.
Think of the wheels/tires as flywheels. The heavier they are, and the more mass concentrated further out, the harder it is to accelerate and decelerate them.
I recently tested a vehicle (car) where all we did was change from 17" wheels to 20" wheels, with the rolling radius very nearly the same, and we saw a decrease in fuel economy of about 20%. Not only where the wheels heavier at about 62 lb, vs 37 lb, but that extra mass was distributed at a bigger diameter.
Also, the 20" tires were inherently less efficient.
Tires have an efficiency rating (usually not published) that relates the energy it takes to roll the tire under load (basically, how the energy require to make the tire continuously deform its shape as it rolls around.
In general, the OEM selects tires with a pretty good efficiency rating since they have to run those tires when the official EPA MPG numbers are determined. However, by far, most aftermarket tires, whether original size or not, have a lower efficiency number. Sometimes much lower, and that can cause a big FE reduction.
Since these numbers are not generally published, it can be very hard to tell what to select. You can always try to go with the OEM tires to preserve the FE but if your like me, that is not a very desirable option
And when it comes to tires that are much, much different than the OEM setup, like off road tires or 26" tires and such, all bets are off. You can easily drop 30-40% on you FE.
candyman74
arnold, mo
i have an 07 suburban and it also gets around 13 mpg and i noticed the person who had it before me put a kandn filter in would that have any effect in the gas milage. it also has 4.10s factory
Brock
Senior Member
NC
Evildude, just please don't buy a Prius.
Well Worn Chevy
