TylerHagerdorn
- Joined
- May 31, 2021
- Posts
- 99
- Reaction score
- 17
Alright I don't know if I've made a post about this or not. So I apologize if I did. More issues with the fuel gauge on my Burb and it's really making me angry, because I don't ever know how much fuel I have. And I've never had this trouble before in the other 3 GMT800s I've owned.
I have a brand new fully rebuilt cluster, cluster is not the issue. The fuel gauge will not sit still where it's supposed to be. Sitting at an idle it will go up and then down and then where it's supposed to be for a short time then start moving again. I'm absolutely lost.
The fuel level sensor wiring goes from the PCM to connector C152, then from there back to the fuel pump. I pulled the connectors off the PCM yesterday and found what looked like straight motor oil drenching the pins and sitting inside the PCM connector slots. I used a whole can of CRC QD electronic cleaner on it and got them pretty clean. And after that last night, got some fuel and the gauge didn't act up a single bit. Fast forward to this morning, took my boy to school and sitting at an idle it decided it wanted to act up again.
Now before this, it would just drop off to completely empty, with the DIC Range display showing three dashes. Then it would come back up and shoot past half to almost full. And would keep doing that back and forth non stop. So I suspect the oil substance was causing an issue with the connection. But it started acting up again this morning. Nowhere near as bad. The gauge just will not sit still where it's supposed to be.
So my question now is where do I go from here? Do I cut the wire closer to the PCM, and run an overlay and run it directly, bypassing C152 all together? Do I go to the junkyard and get two PCM connectors that have not been soaked in oil and splice them in? I truly believe it's a connection issue now. I really don't want to drop the tank if I can help it. Especially after putting 10 gallons in last night. And I don't have a shop, just my apartment parking lot.
Any help would be very much appreciated. Thank you guys and have a wonderful day.
