Hi all. I've read through most of the posts here. What is the correct spec for fuel pressure on a 5.7 L Vortec in a 2000 GMC Yukon Denali?
I tested mine, got 51 psi key on engine off, and a brief dip then consistent 50 psi with engine running at idle. I turned it off, and pressure holds, not bleed down.
I've read 60 - 66 psi is needed. Is that correct?
