Donkey Punch
Panantukan
Long story short, replaced my fuel pump with one from autozone. bad idea? who knows but my fuel pressure reads 62 psi while cranking and it'll run for a few minutes then it'll stutter and shut off. I checked my relay prior to replacing the pump and the pcm seemed in control of the relay and pump. But why would I lose power like that? bad ground somewhere. I mean the pump is new right... I checked and even dropped the tank again to recheck my wiring and everything seemed to look fine but I know I am missing something. One thing I noticed was that my fuel pressure is at 51psi while the key is on the ON position and dropped as far as 48 psi after a while.
Leak somewhere? injectors perhaps?
