Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
put a different gauge cluster in the Yukon and it did the same thing. It must be something in the wiring/sending unit but it all tests out ok .....out of ideas
The fuel level signal travels thru the pcm and a bad fuel pump should have not cause a blown pcm fuse. the pump is controlled by a relay which is controlled by the pcm. It is likely you pcm itself has failed. Use the linked procedure for diagnostics.
fuel pump runs off the pcm b fuse. anyway i got it fixed. the plug on the new oem module was bad. I put the plug from the old module into the new module and everything works.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
