douglasdouglasj
- Joined
- Jul 7, 2013
- Posts
- 5
- Reaction score
- 0
Anyone got suggestions on this? Yesterday, I went to pick up my girlfriend from work, and turned off the truck. Started the engine about 5 minutes later, and noticed a strong gas smell. On the way home 2 miles away, Noticed the truck was bogging down severely and the gas smell got worse. When I got home, looked under the truck and found gas pouring off the bottom of the tank.
Today, I went tou and lifted up one side of the truck and turned ignition to ON, and watched the fuel pump spray the wheel well with fuel. After a little more inspection, it appears to be coming from the rubber pressure hose at the fitting closest to the fuel pump, but cannot be certain.
Heres the problem; I'm very limited on the height pf the crappy scissor jack the truck has, and dont have access to a good jack. Besides taking the truck in and spending 700$ on repair, is there a way to finesse that tank down to inspect those lines?
Ive also looked for the fuel line diagrams, and cant find any info on if that rubber pressure line is removable, or if it's a permanent part of the entire fuel line up to the fuel filter?
