FU's 5.3 to L9H 6.2 thread
FrankU
FrankU
Babylon New York
Here is another cam I'm considering. Both cams are very similar. This TFS cam is proven itself very worthy also:
Brand: Trick Flow Specialties
Manufacturer's Part Number: TFS-30602001
Part Type: Camshafts
Product Line: Trick Flow® Track Max® Hydraulic Roller Camshafts for GM LS
Summit Racing Part Number: TFS-30602001
UPC: 842645107092
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,000-6,000
Intake Duration at 050 inch Lift: 216
Exhaust Duration at 050 inch Lift: 220
Duration at 050 inch Lift: 216 int./220 exh.
Advertised Intake Duration: 285
Advertised Exhaust Duration: 292
Advertised Duration: 285 int./292 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.560 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.560 in.
Valve Lift with Factory Rocker Arm Ratio: 0.560 int./0.560 exh.
Lobe Separation (degrees): 114
Camshaft Gear Attachment: 3-bolt
Computer-Controlled Compatible: Yes
Valve Springs Required: Yes
91RS
GA
Brand: COMP Cams
Manufacturer's Part Number: 156-401-13
Product Line: COMP Cams XFI SPR GM Gen IV VVT Camshafts
Summit Racing Part Number: CCA-156-401-13
UPC: 036584197560
Basic Operating RPM Range: 1,600-6,700
Intake Duration at 050 inch Lift: 214
Exhaust Duration at 050 inch Lift: 228
Duration at 050 inch Lift: 214 int./228 exh.
Advertised Intake Duration: 267
Advertised Exhaust Duration: 281
Advertised Duration: 267 int./281 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.559 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.571 in.
Valve Lift with Factory Rocker Arm Ratio: 0.559 int./0.571 exh.
Camshaft Gear Attachment: 1-bolt
** This is one of the camshafts I'm considering
I have this cam sitting on my shelf waiting for me to get time to install it. My tuner recommended it for me because I still want to use mine as a truck when I need to and drive it on trips, he said it's good for 50hp. I decided to go with PSI valve springs. My father-in-law bought the Gwatney Stage 1 VVT cam for his truck when they were doing a sale a few weeks ago so I'll be very interested to see how they turn out.
FrankU
FrankU
Babylon New York
That Comp cam # 156-401-13 is on back order 4-6 week wait.
Have to get onto the exhaust. The stock 5.3 exhaust Y after the cat's is a huge bottle neck (see below pictures) I know that a set of long tubes is really the way to go but been there done that too many times. See the difference where the head pipes merge ?
5.3
6.2
I was thinking of getting a 6.2 exhaust and a cat back system to let this L9H breathe a bit better.
FrankU
FrankU
Babylon New York
AC spark plug gap supposed to be out of the box gap of .40 all 8 were gapped at a tight .35
Verified the tight .35 with a flat then a wire guage.
5.3
6.2
Magnaflow cats and Y-Pipe is a thing of beauty and flows great. Was good for seven horsepower on my truck.
