Was wondering how OP did the swap. Driveway with hand tools and hoist?
Oh yeah, me too!
Oh yeah, me too!
More and more I am just leaning on doing this in my driveway. Looks like you just remove exhaust, unbolt transmission, remove wiring/hosing to engine, remove motor mount bolts, remove radiator and support? Then yank it out?
Just curious if there are any gotchas and if it can be done in a reasonable time (say 2 days).
Ok so you remove and installed it without heads and intake? Honestly that sounds easier if you're doing it alone anyway.
I did the DOD delete myself over 2 days and the cleaning was the longest part. Putting the heads on and bolting down would be like 30 minutes if everything was cleaned already.
Seems less chance of ******* something up just doing the block alone. Probably longer time, but less stress for sure.
Affirmative. Main reason was access to the top four bellhousing bolts. The engine can be pulled with the mounts still bolted to it and radiator in place. Just pull the fans and turn the engine sideways. The mounts clear the core support and cowl by about 1/2".
That’s what I was thinking too.That's awesome. So nothing on the front clip has to be pulled at all?
