Fuse Questions - Subs
sparg93
Expedition Tahoe
NJ
My Amp: Kenwood - XR-1S
My understanding is that it draws 60A max.
I'm running a fused distribution block that splits 1/0g into x2 4g wires and then to the amp - which fuse should I go with for the distribution block (amp rating)?
This is the distribution block so I will purchase two fuses:
http://www.sonicelectronix.com/item_17487_StreetWires-FBXS024.html
My alternator runs at 130amps, is 150A fuse appropriate for the 1/0g running into the distribution block? Is 150A good for the Big 3?
Thanks!
Any other fuses that I should need?
I'm running a simple setup of x1 Amp to x2 10" subs.
Thanks!
S
sparg93
Expedition Tahoe
NJ
I purchased 80A fuses for the distribution block..is this correct, or should I have gone with 60A?
S
sparg93
Expedition Tahoe
NJ
I'm not really strong in electrical, so please bear with these questions.
What are some of the reasons a fuse would pop?
Why is it better to go with a fuse that is rated just slightly higher then what the alternator produces? Would it better to go with a 200A in case the alt spikes? (is it even possible for the alt to spike)
tsarms
yes wires can short out and the fuses are there to protect. They are cheap insureance
raptorforme93
Tampa, Fl
If you ground out a live power wire or something like that then the fuse will pop so that the wire will then no longer be live. Great for preventing fires. haha
fyremanpat
Fyremanpat
Yea 80's will work fine. If your alt jumps to 200 amps youve got a lot more to worry about then replacing fuses.haha...
traveler613
