Fuse Relay Center (Under Hood)
96_2DRSPORT
Paper Chaser
Baltimore
I know i got alot of questions lol but last summer the wires that run to the fuse relay center for the fuel pump kept burning out the fuel pump relay...
i changed the pump twice last summer but the wire kept burning any suggestions?
718frankb
LOCAL 282 TEAMSTERS
BROOKLYN,NY
did you change the harness at the fuel pump? your getting resistance from somewhere! also check the ground wire above the tank you can be pulling an unbalanced load from a dirty ground
96_2DRSPORT
96_2DRSPORT
Paper Chaser
Baltimore
i changed the entire system but your right it would knock the batter charge down... i am going to have it checked out to see because once it gets hot outside thats when i have the problem
jmm4jmc
