FYI - High Output Alternator
David Smith
Savannah, GA
I am trying to upload a video of my voltage meter, but it will not let me.
Keeps saying "The uploaded file does not have an allowed extension."
What do I need to do?
BigDaddy13440
BigDaddy13440
Rome, NY
Update: the replacement ** alternator and new battery are working great. Can run my amp at full tilt, voltage barely dips at all, and when it does, I'm still over 14.0 volts (charging at 14.8-15.0 from idle to 2000rpm).
Second battery will most likely be needed when I upgrade my amp, going from the 1000 watts RMS (?) to a 2200 watts RMS (certified). Only running a single 1/0 run back to my distribution block (and 4ga to the amp), will upgrade and run a dual 1/0 run to a fused block, and dual 1/0 to the new amp (with dual 1/0 to single 1/0 adapters for power and ground).
Joao GANDAREZ
Nj
I got one of these off ebay for $115 came with sticker that says 253 amps. had it for a few days. Need to do big 3 then see how it works. need to swap in the electric fans aswell. Then comes music maybe
Stevemo70
