G80 not available with vehicles with optional StabiliTrak
strutaeng
strutaeng
Dallas, Texas
I just discovered the other night that it's the same case on my 2004 as well. I was out off-roading and couldn't get my "locker" to lock up so that night I was doing some research and after seeing how easy it was for other people to get theirs to engage in videos I started contemplating if I actually had one. I checked the build sheet and was super disappointed when I saw that note about Stabilitrak. Originally, I had only seen the "locking rear differential" part in the first column, so for years I've been thinking I actually had a G80 when I don't. After I saw that note I checked the RPO codes and sadly there's no G80 code...
I read somewhere that it was only like this for 2003 and 2004, then in 2005 you could get both Stabilitrak and the G80. Anyone know why you couldn't have both for a couple years? I'm wondering if it's possible to install one and still have everything work properly. Also, mine is AWD, not 4WD, which seems to be pretty uncommon for a base model and makes things a bit more complicated in the powertrain.
Also, what does the note mean by it also replaces traction assist? I definitely have traction control, I've seen the "traction active" message come up on the dash several times before.
Umm, not sure about the note that says "replaces traction assist"? What is that? Maybe what they used to call the system that Stabilitrac replaced?
But yeah, clear also states it replaces locking differential.
I'm thinking GM in those 2 years hadn't really figured out how to make the 2 systems work together? Once they figured it out, they brought back the locking differential?
If you put a locking differential on your truck, you could either get some unwanted brake applications through the EBCM or some sort of error message? I'm not entirely sure.
Justinj360
Your guess is as good as mine on that one.
Yeah that's all I can come up with for those 2 years too. Maybe at the time they also thought Stabilitrak was good enough or maybe even better?
Marky Dissod
StabiliTrak and the locker did not seem to work well together with a physical throttle.
Once GM switched to signal throttle, maybe that made it easier to combine the locker and StabiliTrak?
Justinj360
Do you mean like a cable throttle? My 04 uses an electronic throttle. I think they switched from cable to electronic with the updated model in 2003.
Marky Dissod
Yes.
Cable = Physical = REAL = I control throttle, pcm must deal with MY WISHES!
Signal = Electrical = I get to make suggestions to the throttle,
ecm & tcm briefly discuss and then agree on what I meant, gottdamnt
(this is why throttle fakers nearly always quicken the throttle somehow, and why ecm tuning is still desirable)
The switch from real to 'by-wire' throttle started in '03 for most Gen3 V8s; think ALL Gen4 & younger are 'by-wire'.
Rink
