gas tank issue
95escahoe
Good evening, I've got a 95 Tahoe and if you fill the gas tank up more than 3 quarters it leaks a lil bit the guy I picked it up from was saying the sending unit seal was bad possibly? has anyone ever had this problem before, aslong as I keep it below the 3 quarters of a tank its fine its, and when this happens it seems to be coming from the top of the tank too, thanks for the help
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Not personally.It is actually the gasket for the fuel pump/sending unit assy mounting to the fuel tank. It is only a few dollars but your fuel tank needs to be removed to do it. Parking at large inclines can leak with less gas. Make sure your fill pipe is securely attached.
95escahoe
95escahoe
thanks for the info, was looking up online how to drop the tank doesn't sound too bad to do
96ProCompTahoe
IN
i had that problem, pulled the pump assembly out to replace it, put it back in pump crapped out a few days later...
pretty simple to switch it out.
grnrpr68
Davenport IA
yea if you are goin to replace that gasket you might just want to replace the fuel pump as well since your in there already that what i did......gl
95escahoe
95escahoe
damn that sux, ya ill prolly do it at the same time then don't wanna have to drop the tank twice
96ProCompTahoe
IN
Yeah dropping that tank twice in a weeks time was ridiculous. Pretty sure when I had the pump out of the tank it dried out which caused it to seize up. Just make sure to use the Delphi pump and not a cheap off brand.
95escahoe
95escahoe
dont break the clips or the lines.... fyi, lines are about 150 bucks each from GM :)
oh damn, thanks for the heads up
---------- Post added at 02:47 PM ---------- Previous post was at 02:45 PM ----------
I try to stay away from the cheap stuff,always try to go with ac/delco or another good brand if they dont stock it
bufaton
