gauges!?
RIMZ24
Speedway, IN
Need a lil help here... I have a 05 Tahoe 5.3, today I got in started it up to go to work, started driving and the speedo didnt move. Pinned at 0. I got to probably about 35mph or so and it jumped straight up but it sorta bounced around. Stopped at a light and just as I was taking off the rpms fluttered and it hesitated to accelerate. Anyone have any Ideas on where to start? Any help at all is appreciated thanks!
Sepiroth
I am here
Kouts, In
Hmmmm. Did this continue throught the day? Was this the only time you drove the vehicle today?
dub02gpgt
dub
WI
my gauges freaked out on me too. GM extended their warranty on the gauges to 70,000 miles so that might be worth looking into...
Timmy
Brunswick, GA
probably a stepper motor. i think gm put out an extended waranty on the clusters.
R
RIMZ24
Speedway, IN
but the stepper motor wouldn't cause the fluctuation in the rpm and acceleration would it?
05Yukon
Houston
If your 05 was built in 04 and has 80K or less GM will cover it.
PavementPounder
Cincinnati
You have two problems. First one is the cluster is fugged. If you're under 80k take it to your local dealer there's special policy for the cluster. That would not effect lack of acceleration or flutter.
R
RIMZ24
Speedway, IN
does anyone know what the TPS voltages should be on these trucks. I have a 2000 Durango and I ran into a similar problem with the rpms and it ended up being the TPS. I guess that would be a place to start looking. Thanks for the help guys!!!
Carlos123
