gear puller WTF? Torsion bar key removal
TheFuzz
Idiot Police
Spurbury, VT
Do NOT unbolt the crossmember. Use the gear puller or torsion bar tool as noted in the above link.
Narco
Atlanta
we used a gear puller on mine to remove the keys last week and it worked PERFECTLY. no way id ever pay $100 for a tool ill use once.
ryangt
ryangt
double team supreme
Jacksonville, Florida
well, against better judgement i went ahead and purchased a rough country c-clamp style remover, anyone else in the outback with a GM is more than welcome to come over and use it. This thing will more than likely get stuck on ebay next week so keep your eyes open.
Narco
Atlanta
you should post it for sale here 1st...someone might pick it up. wish you had just got the 2/3 gear puller
ryangt
ryangt
double team supreme
no, i have a few gear pullers actually now, but i was really uncomfortable with how they seemed to move while the torsion bar was unloading, i wanted to be confident when i went to remove the bars that i was safe. The C-clamp really is a supreme peice to have, its so strong and dosent even budge. Also i figured out that removing the adjuster bolt by hand is unsafe, an impact wrench should be used for sure, it sped up the removal/install time which equals less time muckin around with torsion keys which = safety !
and yes, thats a good idea, i might just post it up on here after i ride the rig around for a few weeks to make sure everything is groovy with the install.
Narco
Atlanta
the puller we used only moved around a very little bit until some tension was put on it. after that it didnt move hardly at all
ballsie
austin texas
I have lowered a few of these trucks and feel 100% comfortable with the gear puller. It is very solid as long as it is seated properly. The torsion bar tool is a waste of money... It costs more than the keys!
ryangt
ryangt
double team supreme
the only issue i had was it moving the crossmember. Maybe i worded that wrong before. It was bending the lips on the crossmember so i halted the removal at that point. Im not happy about that because even the haynes manual says to use the same gear puller i have haha.
---------- Post added at 08:59 AM ---------- Previous post was at 08:56 AM ----------
i got the superlift kit, it was 209$ from tirerack.com the tool was 80 bucks on ebay. I dont agree with the pricing for a forged peice of metal that is basically a glorified C-clamp, but the way i look at it, i cant take chances out here in the outback, if i break something, im screwed so i better do it right the first time, every time.
