Did the axle seal. Make sure you do not rotate the carrier too much when you pull the pin to get at the c-clip. We moved it too much and spent hours spinning it round and round to get it lined up again to get that extra 1/16 of an inch to get the c-clip back in place.
A large pry bar makes pulling the old one out easy and a block of wood makes seating the new one easier. Remember to put the axle back in the same way so the splines match right up. The diff cover gasket can be reused without sealant if in good condition.
