George B's 2000 Saturn SL2. “The Turtle”
George B
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Got another gremlin to chase.
It got up to 50° today so I tried the AC and found the compressor doesn’t run. All the fuses are good. Looking with the tech2 I can manually command the compressor relay but get a “AC is commanded off” message. I assume this may be an ambient temperature reading issue as manipulation of the AC button doesn’t change the state of the command. I heard that the temperature needs to be above 40° so I should have been good. I will have to look at the data again to see if I can see the ambient temperature input. I don’t have a detailed enough manual to find the sensor itself. I know there is an IAT by the filter but I don’t know if it is shared. The AC relay is controlled by the PCM which also reads the IAT.
May be time for an Alldatadiy sub.
George B
George B
¯\_(ツ)_/¯
More reading and testing are due. I think the pressure switch is all that is used to determine if it’s “too cold”. I need to check the state of the switch and I may need a set of gauges.
DT360
