Get a catch can before any mods.
blkonblk
NYC
Tony where did you get yours?? How often do you have to clean it? Can you do a write up when you have time? I would like to get one
---------- Post added at 12:36 AM ---------- Previous post was at 12:35 AM ----------
Thanks for the links Joe
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
every oil change i clean it out i got mine from catchcans.com
ill take a pic this weekend where i have it hooked up just been swamped
InTruckDesign
SW CT,
Pic of mine when it was on the Tahoe...need to get it installed on the 'Burb.
here is where I got it
http://www.eliteengineeringusa.com/Catch_Can/
08grey
I thought this was going to turn into a DIY. How did it die out?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
It will be once i get my truck back tomorrow.
08grey
Thank you sir. Truck okay?
Sent from my iPad using Tapatalk HD
tights24
Yes, thank you. If you wouldn't also mind explaining which one you purchased, that would be great. I looked at the website and I see 3 different styles. I'm technically inclined when it comes to automation and working on things, but with engines I'm pretty much a rookie with what is where unless I've had to work on it in the past. I know major components, but when it comes to "this line is going from the canooter valve(teehee) to this valve" type thing I'm lost. Thanks again
BigBlueLB756
By Marion, MS
Anybody for something cheap that works pretty good?
The filter element substituted for the one inside is made of:
Cut round pieces as needed.
Unscrew the bowl to empty.
Lowe's or Home Depot can fix you up with the separator, 90 degree barbs, and hose clamps. 3/8" hose as needed from parts store. Cost about $35.
cpranger22
