Gmpartsdirect.com Or???
Rozay
Rozay
The problem is where/how to buy them. It doesn't seem that DJM sells them separate. Only part of a more expensive rear "kit".
I emailed them and they sent me a link. But they want $22 to ship them for a $64 product. That’s a hard one to swallow
Hi-psi
Atlanta, GA
Yeah, that sucks. If leaving the links just straight was viable, that's a relatively easy fix. Cut the stock ones, thread each end, and get a threaded coupling to make the length adjustable.
But in addition to being shorter, the DJM ones are offset and relocate the sway bar a little for pandhard bar mount and sometimes shock clearance for when it articulates.
Hi-psi
Atlanta, GA
Good approach to using the factory style straight links and still off-setting the swaybar. So, using the idea of cutting the factory links in half, removing a little length in the center, then threading the rods/shafts and using a threaded coupling for adjustment is certainly a good budget alternative now that the DJM ones can't be had affordably.
Or if you have a the skill and a welder, just cut the factory ones, measure, remove length, weld back together.
mattt
GMPartsDirect.com is a JOKE and waste of time! Their customer service is NON-EXISTANT! Try looking up water pump or oil pump for 04 Tahoe, no listing that I found. Every other nonsensical part comes up when you search, but not what you're looking for with a directed search.
So I tried calling them MULTIPLE TIMES, no answer and no returning the voicemail left. Tried Emailing them too....no reply at all.
What the H is wrong with that company?
tony97218
