going to start gathering bag parts but need help
MOBmentality
Has a $25,000 Punch
thats alil scarry
well on a bracket setup its still just one bolt holding it on.. to a flat plate.. the only difference is the bolt is a bolt.. which can come out.. vs.. this way its a threaded rod... that cant.
MOBmentality
Has a $25,000 Punch
http://www.jegs.com/i/Air Ride/029/A079A/10002/-1?CT=999
Something like this for the bottom... BUT.. drill the center hole a little bigger and flush weld a nut into it.. put tiny spacers AS SMALL AS POSSIBLE on either side.. to give yourself room to weld it flat and account for the nut... then weld it to the axle and put a lil scrap steel supports on either side from the bottom..
::drawing a pic now::
mikeyboy
mikeyboy
freeport new york
mob your the man ha ha
---------- Post added at 10:52 PM ---------- Previous post was at 10:49 PM ----------
are u saying to put the nut on the bottom or top of the bracket if it is on the bottom then why whould i need spacers
MOBmentality
Has a $25,000 Punch
The spacers are because youre going to run a 1/8 inch steel flat bracket.. and its gonna be a 1/4 inch nut.. so you have to make up for a 1/8 inch somewhere.. shit for 12$ a bracket you could just order 2 for each side and stack them and it would be better than any spacer on the planet
I cant imagine doing a better bottom end for a boa setup.. after you did this just make sure the top is as flat as the air fitting will allow.. and youll be ****
---------- Post added at 11:06 PM ---------- Previous post was at 11:02 PM ----------
the only way to go shorter with a boa setup would be.. to get the top super flat.. i dont remember when the top looks like.. but if you could weld another flat bracket to the top and tap the line straight out. (into the floorboard? grommet seals?) you could easily pull an extra 2 to 4 inches more out of a boa this way
mikeyboy
mikeyboy
freeport new york
ok i see ill prob order those brackets monday
---------- Post added at 11:10 PM ---------- Previous post was at 11:07 PM ----------
so cut the stock rear brackets off correct ?
MOBmentality
Has a $25,000 Punch
i THINK they are already pretty damn flat.. dont sweat cutting nothing thats not gonna save space.. too much cutting and we might as well have done a mock 4-link
The top is where im blind.. i dont remember the top at all.. fat should be able to help us there.. maybe get us some pics
TEXAS DEMON
with a vengeance
texas
for the rear upper bracket (oem) it would have to be removed and weld a flat bracket with gussets on the sides. oooooorr you can notch a good section of the upper bracket to have clearnce for youre fitting and air line. i would recomend that you don use 1/2 line,it will be hard to bend it up there.what i did on mine was welded the bottom bolt to the bag, then spund the bag around to screw it in, if you need to to remove it or work on it just raise the the body let the axle go as low as it can and the upper part of the bag will be loose enough to screw it off.
syndicatesteve
Syndicate Steve
Southern California
I am using Lowrider Depots front bolt in braket, with Slam Specialties bags, and I am having all my rear mounts and pan hard bar custom fabricated by Mouses Customs here in AZ. I have Chrome Viar 480 Double Pack. have not acquired the valves or controler yet. Pics to come in about a month
tashaa95
