going to start gathering bag parts but need help
fatnlowtahoe504
New Orleans, LA / Hattiesburg, MS
ok this is what i have for the rear, on the bottom of the cup you can see that there is a tab that sticks out, you can put a heavy duty hose clamp on there that raps around the axle and over that tab, or you can put a tac weld on the opposite side of the cup where it touches the frame as seen in the link below.... as for the top, it lines right up with the factory spring perch and i had to make a slim plate to go on top so i can put a nut on that bolt to hold it to the top of the spring perch....
http://www.ridetech.com/shop/index.php?dispatch=attachments.getfile&attachment_id=48
skyhighsami
With those air bags in the back how does it ride? How much adjustment is there height wise? Right now the truck is 3-5 and I would like to keep it there or close to it maybe drop it one more inch but I need it to ride very smooth
ehernande86
