Gonna be towing soon
popo8
popo8
With "tow/haul" engaged i can use OD, right?
LTXtech.com IS my drug...
OWNER/ADMIN
mizzouguy
Lake of the Ozarks, MO
Someone may correct me here but I believe it WILL still go into overdrive with tow/haul engaged, its just at a different rpm and speed. It'll hold 3rd longer, and on basically any type of hill, then when it flattens out or you dont have much of a load on the engine it'll go into OD. Play around with it off and on on the highway and see what it does, but the tow/haul mode is designed with tranny life and temps in mind. I'd leave it on.
popo8
popo8
Ok... i plan on using the tow haul... just wasnt sure if i should run the caddy in 3 or in OD
OWNER/ADMIN
smccollamjr
Tow/haul works fine in OD. However, if you find it shifting in and out of OD a lot it's best pull it down to 3. A lot is shifting or lugging the motor in a higher gear generates heat in the transmission, but that typically doesn't happen tow/haul.
gat0r
DFW
i left mine in tow/haul driving thru the hills.
some of the hills seemed to hold lower gear to long for my taste, but once it leveled out, all was well
popo8
popo8
Thanks fellas. Leavin in a few hrs.
OWNER/ADMIN
adventurenali92
Big Bear Lake, ca
I would engage the tow haul. Over drive will be fine. You should be fine in over drive. I down shift into 3rd on the steep grades.
popo8
popo8
The truck did great. The squat was a lil more than I liked, but still had rear suspension travel, so it was ok.
I stopped for fuel every time we got down to half tank... which was about 100 to 120 miles.
OWNER/ADMIN
horonym
