Good morning .got the airbag light on
SavageRyder
Michigan
So last sunday as I was driving I noticed my air bag light started flashing and the went off . Today while I was driving to work the air bag light went on for like 10 deconds then off then back on then off . Off and on . The yukon never been in an accident . Any ideas guys ? This thing is driving me crazy
sent from my tweaked out Galaxy S 4
franksbanks
Arizona
air bags are kind of hard to diagnose if you don’t have a scanner-I don’t recommend you to start plugging/unplugging cables and accidently set it off.
Every time you start your SUV the SRS system will run a test. if the light stays on, the SRS system has not met operational standards – (bad sensor/wiring= airbags may not deploy when needed)
have you installed any new electronics (radio, DVD system)which caused wires to be moved under the steering column?
Any front/rear end work? (bumper replacement) there are front and rear impact sensor in those areas- if they were tampered with, it could be the reason of the service light-
Try disconnecting the battery for about 15 mins and see if that gets it to go away, maybe it just needs a reset.
If it still persists, you may just want to get it scanned it for a full diagnostics
If you connect an OBD II scanner it will tell you exactly what code is being triggered and why the air bag light is coming on.
Good luck
Foxer55
