Got my 3" performance accs. Lift kit woohoo
riviera rider
riviera rider
awesome looks like saturday im going to install it. i got my 60gal air compressor and all my air tools at my dads anyway so should go pretty decent im thinking
how bad does the rear bumper look without modding something to raise it up?
blizz
San Antonio, TX
eh..you can hide it. this is what i did with some rubber base molding.
riviera rider
riviera rider
ill fabricate something or maybe just get all the gap guards
blizz
San Antonio, TX
they dont sell gap guards for that space. if you find some material similar to the ones used for the gap guards, let me know. i need some to make some for the rear. the tires jacked em all up.
rucr8z2
Saluda,Va.
why can't you move up the bumper on a 2door its the same on the 4door-- just cut the bottom of the frame at a slant - slot bottom hole in bumper and use the top hole in the frame - bolt up and level then mark 2nd hole then drill a new hole beside the top hole in the frame -----strong as original. the two side brackets are not used anymore...
riviera rider
riviera rider
ya i know the body guy at work said something about just moving it up from the bottom mount to the top one, great ill definetly let him do that then if it does work!
wicked2000
El paso TX
I did the same as rucr8z2 and it came out good. Very easy to do. I still welded and bolted it with one bolt on each side. You need to raise it because it will look like shit.
iaminfiji
