Gonna rip it apart on monday. Hoping its just the seal. Bearing worst case. Like I said no noise or vibrations. Just small amounts of grease and the smell.
---------- Post added at 10:23 PM ---------- Previous post was at 10:15 PM ----------
Any posts of a walk through for replacing axle seals and bearings?
Do you have access to a slide hammer?
Also the first thing that you need to focus on is getting the 5/16" bolt loose that holds the C clip lock pin in place. I've had them break before when trying to remove them. If it breaks off then you aren't going to get the axles out unil you get that bolt out. So don't waste your time fooling with the brakes until you get the lock pin bolt out. HTH
