afpj
- Joined
- Sep 16, 2009
- Posts
- 804
- Reaction score
- 359
I found the problem with my tahoe. It was the wheel hub. The bearings inside where completely gone. after replacing it the abs and brake light went away. For only $165 i fixed the problem. The dealership tried to pull a fast one on my and charge $1200 bucks to fixed the abs module when all that was wrong was the hub bearing. Never take the advice of a dealership unless you know the person working there!!!!
Can you elaborate on how you discovered it was the hub? The first post mentioned wheel bearing checked OK, so wonder if there was a different technique used to check? i've only read to lift up the wheel and see if there's any play at the 12 and 6 o'clock positions.
