Growing up doesn't have to suck
CMoore711
This 6" one was too short to bother with the mesh, so it's all heat shrink:
It runs from the engine block (at the bolt for the power steering pump bracket) to the frame (under an engine mount bolt):
Copied the factory alternator-to-main fuse cable:
With very minor trimming of the mount on the firewall, the lug fit fine:
Followed the original routing and was even able to slip the terminal boot on after a little squirt of B'laster:
I want to replace the battery terminals with some marine post-to-stud adapters. I'll make the positive lead from the battery to the main fuse when I get those terminals. I'd like to make a starter wire as well.
Nice work. Those cables are huge.
When are you going to start taking orders for that Big 3 kit?
Is there a Intro Group Buy price?!?! :)
Sam Harris
Texas
FrankU
Babylon New York
I'm in !
Side note : After the swap to the 6.2 the Tahoe was acting up throwing random codes etc. After trying to diagnose the codes we decided to throw on a few more ground wires ... worked and ran great ever since.
I'd like the chance to go ahead and upgrade the positive side also.
tdeaton3
