Don't worry, I have new shocks on deck for when I drop it. Also working on a possible repurposing of the Auto-Level system.![]()
A classic tease....
Do tell...
Nice!
Nothing extraordinary. Just getting a new compressor assembly and connecting it to Airlift bags instead of the air shocks. I have the short (Nissan Pathfinder?) Airlift bags to fit lowering coils. I'll have to play with the ride height sensor links to fine-tune the balance of lift at start-up with increased spring rate.
Rear bump stops as in free travel mod?Thank ya! It's SOMETHING, right?!
You know how it goes, though. Now I'm plotting on installing those Belltech alignment cams- just doing the little not-so-fun things so I can focus on the big stuff and have it all completed sooner. I'm glad I've already knocked out the bump stop removal!
Oh boy here we go....I am curious how this will work out... I have considered it before myself but was afraid I would blow the bags because they aren't rated beyond 35-50 psi.
The factory auto leveling compressor is capable of up to 150 psi according to the techs I talked to at Arnott.
I have been thinking about adding a second set of shocks to the rear end of the Burb.
The reason being is I don't want to lose the auto leveling feature for the times when I hook up to a trailer or load the truck up with luggage and kids for family vacations...
BUT...
I really want to add the Rancho 9 way adjustable shocks to the rear to take the bucking bronco effect when I go over repetitive bumps like on certain bridges.
I hate how the rear end bounces like an old hoopty with worn out shocks.
Ideally I would like to buy the Rancho shocks with the air bladders already on them like the Arnotts and factory shocks... but that is not an option so my second thought was to just add the Ranchos and keep the air shocks I currently have.
I have already found a set of Ranchos that will fit the rear for my lowered application. They are actually for the front end of an older Suburban so the dampening should be good for a heavy truck but they are essentially the same length as the Belltech drop shocks for the rear of my truck with the 6" drop.
I have also considered removing the rear springs altogether and installing the Trailblazer SS air bags and hooking them to the auto leveling compressor to keep the adjustability and then running the Rancho 9 way adjustable shocks to keep the bouncing to a minimum... so many choices... lol
Oh boy here we go....![]()
BUT...
