Had another lifter collapse at 281K, Now running it as a 6 cylinder
robgreg75
I am waiting for my slow ass house to be finished to change out the cam. I had one lifter fail at 278k so I swapped out the failed lifter but was left with a tick since the cam must be damaged. I drove it a little as a 7cyl then just put the rocker arms back on and said screw it drive until dies. Well on monday another lifter collapsed. So I went ahead and disabled both cylinders (remove rocker arms and unplug injector). On the highway it isn't bad it is just really rough idling.
But every time i start it to drive it is weird for about the first 1/4 mile. You can floor it or be part throttle and it won't go over 20mph and stumbles and burbles, then all of a sudden it wakes up, accelerates and has power and you can drive it as normal as can be expected running down 2 cylinders.
BG1988
has your gas mpg improved?
i suggest try manually shifting gears M2 lock then when over 25mph then upshift.. and let off the throttle when upshifting
Go find a used 4.8 or 6.0, 6.2,
j91z28d1
that's pretty impressive. can't say I've heard of that
robgreg75
robgreg75
I have no idea since the computer has no clue what is going on with the engine
BG1988
Odometer mileage divided by gallons pumped... try and use the same pump for consistency
robgreg75
robgreg75
I know how to do it manually but I am not putting gas in it very often since barely driving it.
Levi0320
