2011SSVHOE
I'm an egual oportunity offender
Galante be careful and have fun !!!
Chris, the scan tool is an OTC 3109nlaz Auto scanner. I didn't see anything on the menu for the freeze frame event. I drove her to work and back today, the only thing I noticed is the throttle body seems to be slow to return to idle from say 1500 rpm and seems to be downshifting a little odd. that may be due to the slow idle response, kinda like having your foot on the gas when you are trying to stop, if you know what I mean.
Unplug the MAF and see how it responds. It may seem confused at first, but it should resort to a speed density tune and settle out. Yes, your SES light will be on, but just ignore it for now. If the hanging idle issue goes away, then you're narrowing the problem more towards a fault with the MAF or it's circuit. Since the hanging idle problem seems to have happened after you cleaned the MAF and TB, I'd suggest popping off the intake tube again and checking for any residues. Quite often, someone will clean a TB with a solvent as normal. The solvent loosens the
I've read a few things about the cold air intake tube, how do you check it for leaks?
This is just a picture from google, but if it has an open seam it could probably wreak havoc with drivability. seems like a real stupid design
