Chuck_Finley
- Joined
- Dec 13, 2017
- Posts
- 122
- Reaction score
- 123
yes it is switched I taped 2 places there, one for a LED interior strip to come on with interior lights and the other to power the dashcam when the ignition is on, it was a pain to figure the right one, I can get back under there tomorrow in the day light and see if can get a better picture and color identity.That’s interesting, is the place you tapped next to the brake pedal ignition switched? Can you clarify which wire you tapped? Thanks!
I used the same upfitter port to hard wire my GPS and dash mounted cell phone charger. If memory serves the ignition controlled 12v pin is fused at 20 amps so I put an in line 3amp fuse to each of my accessories.I grabbed these off google.......
This is similar to whats under your dash, left of brake pedal
Uncovered
Open ports, each port has 12v constant, switched, accessory, rap(retained accessory power..... until u open driver door), etc. This is where certain options plug in and where upfitters use for power and such, you may have an extra plug but no matter all the pins are same on each port. A female spade connector will push right on.
I used to have a diagram what each pin was but i cant find it. If i find it ill post it. Easy enough to figurebout with a test light though. Good luck
