Justin Hawkins
I'll have to post a pic this evening when the Tahoe and I are back home.
Great! I am cool with the routing of wires. That's not the issue. It's all about the power!
You got it! (With your fancy-schmancy pic labeling )
You got it! BTW, I recommend checking the wires with a DVOM to confirm they are what you need if they're different colors in your truck than they are in mine. I also don't know what 12V+ circuit that is or the ampacity of it. It's not much of a concern with just powering a radar detector, but I'd like to find out one day.
I will use my multimeter before I do the install and check those and report back.
Under dash to left of brake pedal is a black cover there is fused, switched, acc, rap all right there..Hi all I’m wiring up 2 DVD players to the headrests of my 07 Yukon Denali. I’m not sure what I should tap into for wires. I would like for them to shut off when I open the door just like the radio does. Don’t want to have to worry about my kids turning them off. Any help would be appreciated. Thank you
Under dash to left of brake pedal is a black cover there is fused, switched, acc, rap all right there..View attachment 195171
May not look exactly the same but its there.... just use a dvm to verify
