Has anyone dropped a 00-06 Z71
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
SO Question. Is there a kit to lower the z71 and not replace the shocks? I am looking fo like keys in front and springs in rear. I adjusted the front torsion bar in front and lowered it to the max and really liked the look. It lowered it approx 2 1/4 inches. So 3" keys and sprongs in the back? TONY PLEASE CHIME IN AND HELP ME!!!
if you want a 2/3 drop here it is much better ride on keys then yours cranked
http://www.tbssowners.com/store/index.php?act=viewProd&productId=90
if you have a little more to spend spindles and rear belltech adjustable rear springs
http://www.tbssowners.com/store/index.php?act=viewProd&productId=86
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
the 9956 ground force comes with keys/rear springs and brand new front/rear shocks but no shock extenders. if your getting the shocks then yoru set if not you need to buy extenders which are 75 shipped.
the rear groundforce springs 3 inches leaves a lot to be desired on the ride quality.
boostedgsxr1k
What is the purpose of the shock extenders? And tony, this is ok for the z71? Only reason why I am looking at this kit is because it is dirt cheap (used for 5,000 miles) and I want to know I am going to like the looks of it lowered. And if I do I plan on getting your DJM kit in the future.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
fix angle of the shock esp if your using the stock long shocks.
are you getting the shocks also? how much are you getting the kit for like 200 bucks?
boostedgsxr1k
Yes shocks come with and he wants 250 but he said If I get them tomorow he will alot less
---------- Post added at 12:30 AM ---------- Previous post was at 12:30 AM ----------
and is the ride quality really that bad with this kit?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
for 250 try it out all you need to do is change rear springs if you don tlike it
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
2 inches in the front and 3 inches in the rear.
boostedgsxr1k
ok. Becuase I was told since I have a z71 that it will be like 3 in the front and 4.5 in the rear.
CaptPat
