Has anyone dropped a 00-06 Z71
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
front depends because you can turn keys but that rear 3 inch spring you will be at about 35 inches from ground to fenderlip after you drop your truck. Your truck is not at 39.5 inches now
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
how low do you want to go on your truck?
the djm 3/5.5 kit will put you at 32 in front and 32.5 to 32.75 in rear from ground to fenderlip on a 32.5 inch tall tire about.
boostedgsxr1k
low.. I will have to go measure to be exact. I am running 275/55r20 tires too if that helps. I just want to have around 1 1/2 of wheel gap all the way around
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
with the djm 3/5.5 kit on that 275 55 20 you will be at 31.75 front and 32 in rear from ground to fenderlip.
boostedgsxr1k
ok well tomorow morning I will do some measurements, then bit the bullet and get whichever kit i feel fits my needs the best
chevy1500
suspension
SO Question. Is there a kit to lower the z71 and not replace the shocks? I am looking fo like keys in front and springs in rear. I adjusted the front torsion bar in front and lowered it to the max and really liked the look. It lowered it approx 2 1/4 inches. So 3" keys and sprongs in the back? TONY PLEASE CHIME IN AND HELP ME!!!
what size rims u got on it?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
yeah you should be about 32 inches in front and 32.25 in rear after you drop it. Ride will be fine.
boostedgsxr1k
thanks tony. I just need to save up enough cash to buy it now. I wish I could just win the lottery.
Kreed
