Bob2C
I have these and they are a huge improvement over OEM halogen. They are just crap. Hey provide no lighting at all.
Then I reckon you are used to the new lighting standards. I'm older and do not care for those newer, brighter lights. Not necessary IMO. The lights of modern police cars are too bright, blinding to these old eyes and even our teenage drivers.
I reckon I just want to see the road.
This 1999 is the newest vehicle Ive owned. Im far from spoiled. See the pictures I posted ... There is literally no illumination
I'd suspect you got what you paid for, cheap Ebay Chinese aftermarket knock-off junk. I'd chalk it up to a "cheap" loss, find yourself a brand new set of new OEM GM Lights, you'll pay more, but get the quality you want. LMC Truck might be another option, and again they'll cost more but might likely be OEM.
You've probably noted just how cheaply made they are built in regards to the adjusters, and everything about them.
I know many such lights and housings come with Lamps-Bulbs included, they too are likely garbage. Again you get what you pay for. I've had good luck with PIAA Lamps on both low-high beams.
Were your stock lamp housings really that bad? Is it possible you might be able to clean these up with some varying grades of wet sand papers and compounds and polishes? Then coat them with a good Ceramic Coating such as Carpro CQuartz, or Carpro DLX. Regular Waxes and Sealants just won't last, and hazing-clouding will quickly return since you then likely removed any-all UV coatings that might've been left on the lenses.
Lastly, and while not much help when using low beams, but are the icing on the cake when needing your highs might be to install a Hi-4 Kit, thus when needing High Beams, all 4 Beams light, rather than just two. It makes a considerable difference on dark country roads.
I've always felt the stock lighting on these Tahoes were absolute shit to begin with, inadequate.
