Heated and Cooled Cup Holders
376ci
376ci
Canada
I don't understand your question, the console has nothing to do with the wiring?
I took my power and light sources from the HVAC connector and made my own harness.
Just to make this clear, nothing from the escalade center console cup holder assembly fits a Denali/Yukon.
M3kanic
I'm talking about transplanting the entire center console of an Escalade.
Sent from my SM-G900V using Tapatalk
petethepug
Michael
SoCal
Has anyone else installed the Escalade Heated and Cooled Cup Holders in their Denali?
59294
This is good info. I've seen a previous write up / or pictures of this modification. It may have been in a Tahoe. I stumbled into a seller on eBay selling the later version of the units for $100. Grabbed one back then and it's sat on the project shelf for quite a while. When I install mine I'll likely have another Denali standard cup holder to hack up and work off of so there isn't a gaping hole in the console.
Here's what I'm working with. The 1st start of this little project is to determine the pin out of the connector and verify it's in good working order. I should find out really quick what the "scrap" tag means.
08grey
I thought the amp from the denali made a fitment issue.
Sent from my SM-G950U using Tapatalk
petethepug
Michael
SoCal
It's been done more than once and worked around. We'll see what's going on once I'm in there. I'm in no hurry so I'm also going to see if I can find part of the harness for it at a scrappy.
petethepug
Michael
SoCal
Anyone know of a good Escalade wrecker in Cali. I’d like to have them pull the harness for this cup holder or at least get the matching harness clip and straggling wires to start a bench test.
rowerowe614
