Heated O2 Sensor Readings?
EddieC
I chased down why our remote start system was not functioning and as someone advised it was the CEL that related to one of the O2 sensors (Bank 1 position 2, downstream drivers side). I swapped in a new oem sensor, cleared the code and cured the remote start issue. Unfortunately after about 30 miles the CE light is back on.
I ran a "live" operating scan report on the O2 sensors and that same one has different mV report than the other 3. The other 3 vary but much of the time are around 750 mV. The questionable one is steady around 450 mV.
Is that a problem and if so what could be causing it?
I rechecked the connector and the new connection plug is securely in there. The only thing replaced was that sensor and it's attached wires/plug.
I don't see nibbling on the wires but it is an inconvienance spot to be peering into.
CaptainAmerica1
Arlington TX
Or maybe the fuel trims are getting adjusted back to where they need to be and it just takes a bit to dial it in…
Is the heater circuit working? Got voltage on the two heater pins and will it light up a taillight bulb as a test load?
EddieC
EddieC
Which would those be?
Foggy
KS
Once the engine is warmed your upstream O2 sensors will bounce up and down.
Anywhere from 0 mv up to 999 mv. and they bounce constantly. If the output is NOT
bouncing, it's not working
You'll obviously have the code for that side. If you go to the trouble to swap those downstream sensors side to side, see if the code moves to the other side.
EddieC
EddieC
Yes, both upstreams are bouncing from about 50 up to 750+
nwalk7800
