Help! 07 Yukon died on side of road!
Chasto22
I also changed cam sensor, and crank and both knock sensors...did this first, then did the oil seal and new oil filter and lucas treatment and have not had a stall since, have had intermentant stabilitrac light but will go away after 10 min and takes roughly 30 min of driving to come on again if in town
Chasto22
What im wondering is if you think a thicker synthetic oil over all and a jug and half of lucas would fix fix it and keep the light from coming on
mixup52
Have you also replaced your camshaft position sensor? I'm thinking that might also play a role here right?
Did the cam sensor twice, no help.
I did 10 40 with STP and that helped a little bit. I think staying with the 5 30 and lucas is a better option since the motor was engineered to 5 30. The lucas helps stabilize the oil.
Chasto22
I have also read in a forum somewhere...that a guy had the vvt disabled through a tune and it has kept the code from surfacing. Has anyone else herd of this?
scoobydont
