CKP is Crankshaft position relearn. The CK stands for Crankshaft and the P is for position. Have to have running for the steps suggested:
How do you relearn a crankshaft sensor without a scanner?
- Turn off all of the accessories.
- Accelerate the vehicle to 55 mph at. part throttle. ...
- Cruise at 55 mph for another 5-6. minutes.
- Decelerate to 45 mph without. using the brakes, and maintain 45. ...
- Perform 4 deceleration cycles, ...
- Accelerate to 55 mph and cruise. ...
- Stop the vehicle and idle for 2.
What happens if I don't do a crankshaft relearn after replacing the crankshaft sensor?
Failure to do
such will result in over revving of the engine, causing possible engine damage. 8. Once the engine has returned to idle, check the status of Diagnostic trouble code P1336. If the scanner indicates that the CASE has been learned, the relearn procedure is now complete
