Help: 2007 PPV Rear Differential Spider Gear Kit & Clutch Plate Set
992dr
Eastern N.C.
Do you have Detroit TrueTrac part # for Tahoe PPV?
Man, I'm sorry I cant find the part # for the life of me.
I don't think there's any difference between a PPV and civilian model so you should be able to order one without any problems.
J
jz57
Thanks any way for the effort. I downloaded a copy of catalog from Eaton, there is a model # matching to 1/2 ton Chevy truck.
Dmascari1984
Houston, Tx
If you had a clunk when pressing the accelerator after coasting did this by any chance fix that??
J
jz57
While in the market for new Eaton TrueTrac differential, I found that Eaton out sourced that item. Eaton TrueTrac differential is made in Taiwan.
992dr
Eastern N.C.
I've had them in two other vehicles as well as my Tahoe, roughly 13 years, g-d knows how many miles and I have had zero issues.
HardyHoe
I went with Eaton after exploding rear diff. in my ‘95 2dr 4wd Tahoe (had just replaced clutch & was spinning out after stopping at the end of a dirt road & I hammered down while making a 90 degree turn on to the blacktop, when those tires hit the asphalt @ 4000+ RPM & both wheels hooking up it sounded like .50 caliber in back seat, L & R rear axle shafts shimmied 2’ out each side after I put her in 4 Hi & frontend pulled me about 1/2 mile before noticing the wheels were moving «—») that was in 2002 and haven’t had a day of trouble from my Eaton Posi-Locker
76Fordelite
