Help changing my FPR
millstodd
Hey guys, I guess i'm going to take the daunting task of changing my fuel pressure regulator today, but i need help. I'm not ASE certified by any means, but I'm pretty good with a wrench. I have a '99 Yukon 5.7. I THINK I have to 1st remove my fuel spider. Is this correct? Could someone give me step by step directions? I tired of my Yukon running rough, and 3-4 second cold starting. I just really need a confidence boost, since I need this to be up and running for work on Monday. Any help would be appreciated.
Thanks in advance!!
SunlitComet
OBS Jedi-Do Good
unknown at this time.
not really on removing spider first but you have to remove all that covers it.. and don't change the regulator. Replace the whole spider assembly. there is a new redesigned one that is a huge improvement over the old and has new regulator on it already. Delphi-FJ10566 amazon price will vary depending if they have them in stock at the time or a amazon merchant does. amazon direct price is $224 but they keep getting sold out because it is the bomb.
So once again if you have the old injector system DO NOT REPLACE REGULATOR. DO WHOLE UNIT. Trust me. It may even give you a *****.
If you still want instructions now let me know And I will post it for you later. lacking tech data access at the moment.
---------- Post added at 10:05 AM ---------- Previous post was at 10:04 AM ----------
BTW :welcome:
---------- Post added at 10:09 AM ---------- Previous post was at 10:05 AM ----------
oops won't have it fixed by Monday unless you buy unit at local store for a lot more money.
---------- Post added at 10:13 AM ---------- Previous post was at 10:09 AM ----------
data is working again. print this out.
Removal Upper Intake Removal
166822561
  1. Negative battery cable.
  2. Air cleaner intake duct.
  3. Wiring harness connectors and brackets and move aside.
  4. Throttle linkage and bracket from upper intake manifold.
  5. Cruise control cable, (if equipped).
  6. Fuel lines from intake to the rear of the block.
  7. PCV hose at upper intake manifold.
  8. Ignition coil and bracket. Refer to: See: Powertrain Management\Ignition System\Ignition Coil\Service and Repair
  9. Purge solenoid and bracket.
  10. Upper intake manifold bolts and studs.
    • Mark the location of all studs for proper reassembly.
  1. Upper intake manifold.
---------- Post added at 10:13 AM ---------- Previous post was at 10:13 AM ----------
Installation Upper Intake Installation
Install or Connect
166822561
  1. Upper intake manifold gasket.
  2. Upper intake manifold.
    • Use care not to pinch the injector lines between the upper and lower intake manifolds.
  1. Upper intake manifold bolts. Note the marks made at disassembly for proper stud location. Tighten
    • Bolts in two steps.
    • The first pass to 5 Nm (45 lb. in.).
    • The final pass to 10 Nm (83 lb. in.) Install the two corner studs first to help align the two halves.
  1. Purge solenoid and bracket.
  2. Ignition coil and bracket.
  3. PCV hose at upper intake manifold.
  4. Fuel lines from intake to the rear of the block.
  5. Cruise control cable.
  6. Throttle linkage and bracket from upper intake manifold.
  7. Wiring harness connectors and brackets.
  8. Air cleaner intake duct.
  9. Negative battery cable.
Ceejkay
Ft. Lauderdale, FL
i just did my spider today its not that bad.. word of advise, get new plentium gaskets and make sure you have a tq wrench, other than those 2 things you really cant screw up much
99Yuk
Northern Ontario, Canada
I did mine in 18 hours, but then again I broke a bolt.
Just be very carefull when tightening.
Oh and don't forget the vaseline! I used baby powder scented. My engine bay smelt good for a while. :D
I've been readin this thread and your other thread. You've never actually mentioned in either if your replacing with a new spider or the MPFI upgrade.
And finally, you've never mentioned why your replacing the fuel regulator. I'm not a mechanic, but to me if your having fuel pressure issues, wouldn't you be looking at replacing the fuel pump/sending unit?
Anyways, hopefully this will all work out for you! Good luck!
M
millstodd
Thanks guys. I ordered it last Saturday....we'll see what happens.
janabanana
